Bending purfling?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=45874
Author:  Cablepuller [ Fri Jun 12, 2015 1:47 pm ]
Post subject:  Bending purfling?
Hi
Having recently had to add a larger binding channel due to a router accident i am now going to add purfling under the binding on the sides
This will mean the purfling will have to be curved sideways
I was wondering whether it will bend ok on an iron sideways without unglueing the 2 parts of the binding or should it be done separately ..is a steamer better for this?
(Its wood purfling by the way)
And any other tips please on making this a stress free process
Thankyou
Author:  jack [ Fri Jun 12, 2015 2:00 pm ]
Post subject:  Re: Bending purfling?
if you're using wooden binding, glue the binding to the purfling first, then bend the glued binding/purfling combination as if you were bending just the binding..
Author:  Clinchriver [ Fri Jun 12, 2015 4:12 pm ]
Bends good :mrgreen:
Author:  Phil J [ Sat Jun 13, 2015 6:55 pm ]
What kind of glue do you use to glue the purfling to the binding?
I am thinking of doing this on an upcoming build but was afraid the purfling would come unglued during the bending process.
Author:  Cablepuller [ Sun Jun 14, 2015 4:36 am ]
I use titebond phil
Author:  Clinchriver [ Sun Jun 14, 2015 5:25 am ]
My sole use for titebond lll it takes the heat so to speak.
Author:  Phil J [ Sun Jun 14, 2015 3:28 pm ]
I'll pick up some Titebond 3 and give it a try then! Thanks!
Author:  Mike OMelia [ Sun Jun 14, 2015 4:48 pm ]
I have been reconsidering this approach, mainly because of tight bends. But, I'll admit I don't have any good ideas. Too many times I've had bad luck in the tight turn areas. So, if there are other ideas, I'm listening.
